Hello.
I have a problem, im sure i installed cobik studio on like 4 computers i use, and i wanted to show someting about the program to my friend...
At this point, when i wrote my serial and email in cubik updater, it said there is too many users using the license...
Any ideas?
i know it may be a limit on how much computers at once can have installed the software with the same account, but am i right? and if so, can someone tell me if there is a limit and how big?
On how many computers can i install the software. [Solved]
Re: On how many computers can i install the software.
And also... Can i somehow "reset" the limit? it's problematic, if i get the new computer, how can i be sure that cubik will not deny the registration on the new one?
Technically it's only meant to be on one computer, but obviously that isn't enforced.
If you need it resetting you just have to ask. As long as you aren't obviously abusing the license it'll be reset.
1 x
Yes i obviously agreed to the license and i always read it before i do something that im not sure is "safe" at some point.
Thank you so much for help, i see that you and sphax always want to help your comunity. The "cubik" comunity is very nice, i've never met something like that before.
1 x
i want to explain, that i have the software installed on only two computers, i delated it on other two because of the terms obviously.
Re: On how many computers can i install the software. [Solved]
A user should never reach the limit of share serial. If it is reached, it's generally an abuse (= shared serial with a friend). But we are quite flexible, even knowing Cubik is very cheap.
Well.. i've never shered my copy with anyone else than me... But i'll tell you this again i have installed the program on 4 diffrent computers, but every time i installed it on new, i delated it on the old one... You know... I really like my money and i don't want to waste it by abusing licenses.
In Poland your program isn't cheep, here it costs around 100PLN for us, it's like 100 Euro for you
Yes, a Cubik user is authorized to install the software on up to 2 computers (generally a desktop and a laptop or a desktop at home and desktop at work). You've been able to install on 4 before the warning. Uninstalling Cubik doesn't do anything to your serial. Only the number of different computers running on same license does something.
1 x
Oh... so in this situation... Can i ask for reseting it? im in process of building a new computer and i'll probably install the softwere on it. By the way, thanks so much for help, as i said i've never met such nice comunity
Also im trying to run the animaker from download below cubik on this website. Am i allowed to do this? Just want to ask before any problems.
