Here is a model of Harry Potter's King's Cross Trolley made with Qubicle and CubikStudio, Enjoy !
(for @PoudlardRp minecraft serveur)
Re: Harry Potter's King's Cross Trolley
The gradiant on the chest dosen't look good on Sketchfab ...
The model is pretty good. However, it looks like you used wrong conversion method from voxels to elements. For such detailed model with many different colors, you should use the method "1+ elements per surface". That will generate a lot less elements.
You also should optimize your model (click on the bolt icon button in element edit-mode).
Also read this tutorial to improve Sketchfab rendering of your models: tutorials-f4/how-to-setup-sketchfab-mod ... r-t35.html
Thank's for yours advices, I used the optimization tool for this model and it works
