Hello guys! using the display settings under preview ive been trying to elevate items higher when its on an armor stands head > http://imgur.com/a/ZafTy
but i have ran into one problem, when the armor stand is below ground the item gets very shaded > http://imgur.com/a/qaqE1
Armor stand shade problem when underground [Solved]
- CptJackSwagg3r
- Likes: 8 x | 1 x
Re: Armor stand shade problem when underground
i think i understand your point of view
but there are a few problem
- first of all this bug is out of hands for the cubik team becuse the bug lays in the game it self mojang is reposeble for this not cubik
- reporting this to mojang using the bug tracker would not solve your problem aswell mojang is already aware of this problem but are not able or want to fix this bug
- if you want to fix this so badly try make the armour stand stand on a light source for example glowstone / sea lantern
a life Without cubik is no Life
Re: Armor stand shade problem when underground [Solved]
It's not a bug. Ofc it turns dark while underground.
You can turns your armor stand invisible with /summon ArmorStand ~ ~ ~ {Invisible:1} or /summon armor_stand ~ ~ ~ {Invisible:1b,Invulnerable:1b,NoGravity:1b}
Better to use invisible armor stands than hidden ones
i have tried this, still shade problemFistoF wrote: 22 Jan 2017, 19:18 It's not a bug. Ofc it turns dark while underground.
- CptJackSwagg3r
- Likes: 8 x | 1 x
armor stand applies shade to all models attached to it and shade value comes from the block the armorstand is in. If your armor stand is in darkness, then all models attached to it will look dark.
1 x
as i said already try make the armourstand placed on glowstone for example this will fix it or make it inviceble
I have figured out a solution similar to yours, thank your for your inputweshuiz13 wrote: 24 Jan 2017, 18:39 as i said already try make the armourstand placed on glowstone for example this will fix it or make it inviceble
- CptJackSwagg3r
- Likes: 8 x | 1 x
glad i could help
