And the texture becomes like that after exporting to mcpe entity.
UVs are wrong.
https://www.mediafire.com/view/q6neu51higoc76o
Exporting to mcpe entity: texture is not working perfectly. [Solved]
Re: Exporting to mcpe entity: texture is not working perfectly.
I would need your .cubik file and your export (Mobs.json + .png) so I can test what is happening.
Are you sure you have put the texture on right position in modified mob PNG and are you sure you have set the entity texture size correctly?
I have done everything correctly. Can I send model in PM?
this is not solve yet, I just wrong click on some where. and sphax, have you tried?
Here is the .cubik file. I sent from here cuz I coundn't use cubik PM system.. Messages have been in OutBox for a day.
Cubik: https://www.mediafire.com/downlohttps:/ ... hxcc1gk3nu
It's in outbox until I read the message. Nothing wrong
I'll take a look asap
Please explain how you solved it. That could interest other users.
