all my old models exported goed but now they wont.
i have made 3 models after the updait and when i export it for minecraft. they ar a 1 block with purpel and black. if i load my old models they wil export normaly. what can be the problem?
[fixed]after last updait none of my models wil export good
Re: after last updait none of my models wil export good
attach the .cubik files here and I'll have a look.
You can also attach here the exported JSON so we could see if somewhere went wrong with json export.
Without none of that, nobody can help
this are the models
the old model the new model tnx for reminding me @sphax
The model "freefall" works perfectly (after you fixed a freely rotated element) but the model "magicgarden" doesn't work because some elements are out of boundaries. Minecraft is not precise about out of bounds and does not take in account rotated elements.
So if an element with angle is out of bound without that angle, the whole model model will not load, creating that purple block.
first i was thinking that to but i just made a 1 blok model and having the same problem the blok was 1 pixel at all sides smaller.Sphax wrote: 17 Jun 2017, 07:04 The model "freefall" works perfectly (after you fixed a freely rotated element) but the model "magicgarden" doesn't work because some elements are out of boundaries. Minecraft is not precise about out of bounds and does not take in account rotated elements.
the file in game
into a .JSON file
idk what i am doing wrong.
