Changelog: version 2.7
Post by Sphax » 23 May 2017, 17:32
We've been pretty busy lately but no worry, Cubik Studio will never be forgotten and I am proud to show you this new update!
Version 2.7 contains ton of new things, including some which were asked for a long time!
Using Cubik Studio will be a lot easier thanks to the camera flip (right click on label), faster with its new torus primitive (Mesh edit-mode), accurate with improved voxelization, handy with the new edit button to modify a texture in your favorite picture editor, customizable with the new dark skin and so much more powerful with the 2 new exporters ("MCPE" and "JAVA Mod" formats to model entities)... <:D
:D New features and improvements:
  • :element: Better detection if imported model is block or item and default to block if type is unknown
  • :element: Better texture shortcut support in Elements Material
  • :element: Default name of element is now "Box"
  • :element: New function to automatically sort transparent elements (avoid weird renders in game with transparency)
  • :paint: Added "Edit texture..." menu in Elements Material list popup
  • :paint: New button in UV Mapping editor to edit texture in external editor
  • :paint: New option in Preferences to select Texture Editor executable
  • :paint: New paint tool "Brush square"
  • :paint: Added "L" and "R" labels to selected colors in palette
  • :paint: Custom palette picture is now limited to 16x32 colors
  • :mesh: Bounding box visible on primitives when selected
  • :mesh: New Torus primitive for Mesh edit-mode
  • :voxel: New voxel tool to "select" group of voxels by wrapping automatically blueprint around
  • :voxel: New voxel tool "Shell" which adds voxels all around group of collateral voxels
  • :voxel: Voxel tools are now using right color when right clicking
  • :preview: Added angle parameter to arms and head in Display settings to modify rotation of arms and head in 3rd person view
  • :preview: Removed character preview animation
  • :import: :mesh: New option for PNG importer to import picture as a sprite (billboard mesh which can then be voxelized)
  • :export: :element: Implemented MCPE Entity Exporter
  • :cubik: New "Dark UI" can be selected in preferences
  • :cubik: Right clicking on a view label will reverse the point of view (Up > Down, West > East, South > North)
  • :cubik: New "Rainbow UI" or maybe not...
  • :cubik: Added new options in Model properties for Minecraft Entity type
  • :cubik: Implemented JAVA Exporter
  • :cubik: Added Ctrl+D to deselect
  • :cubik: Added Ctrl+Shift+I to inverse selection
  • :cubik: New select by name command (now usable with F3)
  • :cubik: Improved rename command for elements and meshes
  • :cubik: Change F1, F2, F3 keybinds (cubik forum, rename, select by name)
  • :cubik: Better File selector dialog extension filter
  • :cubik: Added x86 or x64 in About Box
  • :cubik: Error message when no element in model for MCPC JSON, MCPE JSON, Optifine JPM, MC Mod JAVA format exporters
  • :cubik: Added and modified several tooltips for better explanation
  • :cubik: Despite some things added some covfefe
:3 Bugs:
  • Fixed bug with bleeding fill inside mesh during voxelization
  • Fixed bug with large or high texture in Textures UV editor (too large horizontal scrollbar or too short vertical scrollbar)
  • Fixed old bug which prevented the UV to be refreshed when UV editor was opened for the first time
  • Fixed unique ID for elements in JPM Exporter
  • Fixed bug to convert voxel colors to texture atlas (voxel color alpha is not used anymore for texture atlas)
  • Fixed bug with JSON exporter when last element is hidden and hidden elements are ignored
  • Fixed bug with comma in JSON exporter
  • Fixed bug with Meshes list not cleared after voxelization
  • Fixed potential bugs due to not invariant culture
  • Fixed bug when Emptying texture
  • Fixed bug with default save texture path
  • Fixed bug with offset of dropdown list on Hidpi screens
  • Fixed bug with cross button in filter input field which did not work if filter was not validated
  • Fixed bug which was minimizing views when 3D view was maximized and edit-mode was changed
  • Fixed bug with button "Resize mesh to fit middle zone" which was setting origin to wrong coordinates
  • Fixed loading custom palette with alpha
  • Fixed covfefe as well
BONUS: Because you read changelogs, because you are part of Cubik community, because you are awesome and/or because you liked the Cubik background posted on Twitter, here is a wallpaper in 1920x1080 titled "Cubik community big bang". ;)
Re: Changelog: version 2.7
Post by Zeta » 05 Jun 2017, 21:13
Please add 1.8 Export. <3
Zeta
Post by josevazqm » 06 Jun 2017, 01:30
How to export a model to Minecraft: PE JSON entity format? Detailed explanation, please :'(
josevazqm
Post by Cryptic » 06 Jun 2017, 03:37
covfefe
Cryptic
Post by FruitShaped » 06 Jun 2017, 04:27
01000011 01001111 01010110 01000110 01000101 01000110 01000101 ( ͡° ͜ʖ ͡°)
:element: -- :element:
¯\_(ツ)_/¯
Got elements?
FruitShaped
Post by Fabian9799 » 06 Jun 2017, 15:33
FruitShaped wrote: 06 Jun 2017, 04:27 01000011 01001111 01010110 01000110 01000101 01000110 01000101 ( ͡° ͜ʖ ͡°)
010001110110100101110110011001010010000001101101011001010010000001000011011011110111011001100110011001010110011001100101
Fabian9799
Post by FruitShaped » 06 Jun 2017, 17:50
Fabian9799 wrote: 06 Jun 2017, 15:33
01001001 00100000 01110111 01101001 01110011 01101000 00100000 01001001 00100000 01101000 01100001 01100100 00100000 01110011 01101111 01101101 01100101 00100000 01101101 00111000 00101100 00100000 01100010 01110101 01110100 00100000 01001001 00100000 01100100 01101111 01101110 00100111 01110100 00101110 00101110 00101110
¯\_(ツ)_/¯
Got elements?
FruitShaped
Post by HanFox » 06 Jun 2017, 20:37
Please stop with the binary spam.
Post by JujuStyle7 » 07 Jun 2017, 06:23
is it free?
JujuStyle7
Post by HanFox » 07 Jun 2017, 09:34
JujuStyle7 wrote: 07 Jun 2017, 06:23is it free?
All upgrades are free.
