Add a new mode can use the mouse in the main interface to select a range of elements or multiple elements to contrl
This will make the efficiency higher and more accurate
And please add elements merge feature to merge into one or more elements bind together
sry for my english
Select mode and elements merge [Solved]
Re: Select mode and elements merge [Solved]
To select multiple elements or meshes, use Right Shift + Left click. That will draw a selection box
Elements can't be merged but groups are planned in a future update
