Oddly textured in-game display [Solved]
I made a model for a lightsaber in Minecraft. Everything worked fine, however, a few pixels did not display the same as the rest of the blade. The texture png is fine, however its something to do with the model.
- Texture
- 01_lightsaber_1.png (1.71 KiB) Viewed 1926 times
Example.cubik
- Model
- (14.47 KiB) Downloaded 257 times
Re: Oddly textured in-game display [Solved]
The reason this is happening is to do with the order that the elements are in, I swapped the order of the elements in the json file, this should look better.
example.cubik
- (14.46 KiB) Downloaded 256 times
