Optifine's custom entity models allow renders of elements that have multiple angles of rotatation. They also allow for elements to be rotated by more than 22.5-degree intervals. It would be great to have a workspace that allows this.
Thank you very much for the awesome program and the attentive community responses!
Multiple Angles of Rotation for .jpm [Solved]
Reason: Removed "suggestion" from the title
- Barinthusmc
Re: [Sugestion]: Multiple Angles of Rotation for .jpm [Solved]
Thats all already possible. At least the rotation and the optfine element export.
Re: Multiple Angles of Rotation for .jpm
If you modelize something for JPM format, then you can disable rotation restrictions in Model Properties.
