Another issue with the viewport controls
Post by Sidonius » 25 Jan 2017, 08:11
Since the update the rotate view seems to have been switched from Shift + Space to CTRL + Shift + Space. This has created an issue for me.
I use a program called "Always on Top" which pins other programs to top view over other programs. This application uses the keybind CTRL + Space to toggle per window.
The issue now is the new keybind for Cubik Studio also activates the other program's keybind.
I constantly use the two applications in unison as part of my workflow. It's incredibly helpful to have my references right on screen so I can see it, and to be able to change the image on the fly.
I am aware of the background image feature. This is not at all what I am looking for.
Sidonius
Re: Another issue with the viewport controls
Post by alanbecker » 01 Feb 2017, 20:26
you can also rotate with CTRL + middle click.
alanbecker
Post by Sidonius » 02 Feb 2017, 02:02
alanbecker wrote: 01 Feb 2017, 20:26 you can also rotate with CTRL + middle click.
I can't set up a custom marco for that on my Epic Chroma
Sidonius
Post by Sphax » 20 Jun 2017, 16:33
Ctrl+Space = rotate camera
Space = pan camera (move)
There are no such Ctrl+Shift+Space
I suggest you to change keybind of your other application. I can also consider a feature to display a picture (proportionnaly) on right side in Cubik
