Transparency Issues!  [Solved]
Post by Creatos » 14 Jan 2017, 23:32
Hey,
Is there a way to fix the folowing?
There should be stuff inside the transparent window... But it doesn't show up! :(
Creatos
Re: Transparency Issues!  [Solved]
Post by Sphax » 15 Jan 2017, 09:24
It's a Minecraft rendering issue. An item model is rendered in one draw call which does not guarantee the rendering order of polygons.
You can maybe try to move transparent elements to the bottom (or top) of elements list and reexport.
You can try doing that directly in JSON btw
Post by Creatos » 15 Jan 2017, 10:32
Sphax wrote: 15 Jan 2017, 09:24 It's a Minecraft rendering issue. An item model is rendered in one draw call which does not guarantee the rendering order of polygons.
Thanks bud!
It worked, now it isn't invisible anymore and it looks way better! :)
Creatos
Post by Sphax » 15 Jan 2017, 19:20
Cool! :)
So you moved transparent parts at end to make it work?
Post by Creatos » 16 Jan 2017, 16:31
Sphax wrote: 15 Jan 2017, 19:20 Cool! :)
Yes that worked! Ty very much!
Creatos
