Elements with free rotation angles can't be handled in minecraft  [Solved]
Post by CptJackSwagg3r » 07 Jan 2017, 01:59
Hello guys! I made this butterfly http://imgur.com/a/qvrNg it's body is made out of voxels and its wings are made of elements. so far i have made two models of the butterfly (one with wings in a flat position and one with the wings in rotated up) and the 3rd model which is shown in the picture wont allow me to turn it into a json file because "Elements with free rotation angles can't be handled in minecraft". Basically im curious to why it let me rotate the angle of the wings upward but not downward
CptJackSwagg3r
Re: Elements with free rotation angles can't be handled in minecraft
Post by Sphax » 07 Jan 2017, 11:07
Have you disabled option "Restrict rotations" in Model properties?
If yes, enable it.
If no, attach your .cubik file here to let me have a look
Post by CptJackSwagg3r » 07 Jan 2017, 23:14
Sphax wrote: 07 Jan 2017, 11:07 Have you disabled option "Restrict rotations" in Model properties?
If yes, enable it.
Thank you for helping with this, i have tried to export it with it enabled/disabled but had no luck, here is the cubik file > http://www.mediafire.com/file/l59d39hxb ... erf3.cubik
CptJackSwagg3r
Post by Sphax » 08 Jan 2017, 07:57
Please note you can attach files directly in forum without the need of mediafire or something else full of Ads ;)
Post by CptJackSwagg3r » 08 Jan 2017, 08:03
Sphax wrote: 08 Jan 2017, 07:57 Please note you can attach files directly in forum without the need of mediafire or something else full of Ads ;)
Thank you for letting me know, Pls take your time if you need figuring out what is the problem, i know your a busy guy
butterf3.cubik
(2.74 KiB) Downloaded 321 times
CptJackSwagg3r
Post by CptJackSwagg3r » 13 Jan 2017, 04:00
Bump! dont forget about me! :santa:
CptJackSwagg3r
Re: Elements with free rotation angles can't be handled in minecraft  [Solved]
Post by Sphax » 13 Jan 2017, 21:55
Your model has the 2 wings rotated at 20° but Minecraft only authorizes 22.5° steps for rotations.
To rotate at 20° you unchecked "Restrict rotations" in Model properties, do not uncheck this if you are making a model for Minecraft blocks/items
Post by CptJackSwagg3r » 14 Jan 2017, 00:09
thanks
CptJackSwagg3r
