Can't seem to rename the texture  [Solved]
Post by Ashinos » 01 Jan 2017, 01:15
After I create my model and convert it into elements, It shows me the texture which is always called mesh_pallete.png. Since I already have an item using a texture that has the same name I need to rename it so that it can use its own texture properly, but whenever I try to rename it the whole model doesn't have the texture applied anymore and I can't figure out how to fix it. Please tell me what I'm doing wrong.
Ashinos
Re: Can't seem to rename the texture  [Solved]
Post by Sphax » 02 Jan 2017, 18:16
In Elements Material, right click your texture and select "Rename texture..." (not "Edit label...")
Post by Ashinos » 03 Jan 2017, 03:15
Sphax wrote: 02 Jan 2017, 18:16 In Elements Material, right click your texture and select "Rename texture..." (not "Edit label...")
Not sure how I didn't notice that, thanks!
Ashinos
