notextures when importing [Solved]
hi, when i import an obj model with textures define, the model stays black for no reason ive tried importing other models and worked, is due to the size of the image or has it to be square or something? and im running the last version also of cubik.
- theismarius
Re: notextures when importing
Can you send me your obj file, mtl file, texture file, and i take a look ^^ I can´t answer without more details.theismarius wrote: ↑13 Dec 2016, 19:13 hi, when i import an obj model with textures define, the model stays black for no reason ive tried importing other models and worked, is due to the size of the image or has it to be square or something? and im running the last version also of cubik.
- CaptainGalax
- Likes: 13 x | 18 x
Re: notextures when importing [Solved]
If your model appears black in Cubik, that may be due to the diffuse color in MTL file which is set to 0 0 0
You can fix that by modifying the mtl file or by selecting white color and then click on the color button in mesh edit-mode while your meshes are selected
- theismarius
