Texture scaling
Texture scaling
I am trying to make a block with x4 pixels outward to 2 sides. I want it to texture like a normal block, but Studio is scaling the texture to the block and I don't want this. How can I set it to, lets say tile the texture instead?
Re: Texture scaling
You would need to split your block in to smaller elements or edit your texture to already have a tiling effect.
Re: Texture scaling
You can also disable the UV snap in element properties so Cubik do not modify UV when you move/scale an element
