username error  [Solved]
username error
Post by 정찬희 » 20 Nov 2023, 10:43
I purchased and signed up with a different email, but the special characters in my ID were set incorrectly. I entered special characters, but I can't log in.
The email address I purchased is [email protected] username ì •ì°¬í ¬
what should i do
I want to change my username or fix the error
정찬희
Re: username error
Post by HanFox » 20 Nov 2023, 13:40
When I search for your email the username which shows up looks like 정찬희 not the jumble you've posted.
Are you sure you've not got some weird encoding or addon in your browser that's fudging the characters?
Re: username error
Post by 정찬희 » 20 Nov 2023, 14:14
There are no distorted programs or plug-ins. I just copied and pasted the message from the email right here. Username registered as [email protected]
정찬희
Re: username error
Post by HanFox » 21 Nov 2023, 07:56
Yea, like I said, your username on the website was fine. I even checked sending emails with special characters and they sent without being jumbled, so I'm not sure what happened when you signed up.
Regardless, I've changed the username of your account to 정찬희. I assume this is what you were requesting?
Re: username error
Post by 정찬희 » 21 Nov 2023, 09:10
"I initially made a purchase using the email [email protected], with the user name 정찬희. However, when I tried to log in, I was informed that the username was incorrect. After searching for my ID, it appeared with special characters as 'ì •ì°¬í ¬'. Despite attempting to log in with these characters, it was still incorrect, so I submitted an inquiry.
The reason I reached out using [email protected] was due to my inability to log in with the [email protected] account. However, it seems there was a misunderstanding, and instead, the username associated with the [email protected] email was changed from Chan Hee-jeong to Jeong Chan-hee.
There's an additional issue. I made another purchase with [email protected], but as I couldn't log in, I immediately requested a refund. However, a purchase key was generated, and it allows for download. Should I just use this? I made the purchases through PayPal and have requested refunds for both. The refund for [email protected] is still pending, it's on hold. Can I just use the account associated with [email protected]?"
정찬희
Re: username error  [Solved]
Post by HanFox » 21 Nov 2023, 09:30
You should use the account you're currently logged in with and any keys associated it with on https://cubik.studio/get
If your username is still incorrect please state what it should be. However, what it is currently set to is what you signed up with. All I did was copy it from the other account to this one.
I have also fixed the Username Recovery form so it should no longer send usernames in the wrong character encoding. Sorry about that, I didn't realise that's what you were referring to.
Re: username error
Post by 정찬희 » 21 Nov 2023, 23:49
ok i just They said they moved the account, so I will use this ID. thank you
정찬희
