Hello,
I have a problem with the template form not displaying, and I can't find the source of the problem. There is a black and purple block instead.
I am attaching the .cubik file, the blockstate file and the .json template.
For information, the replaced block is the damaged anvil.
If you need more information, please let me know.
Thank you for your help
The shape of the model does not appear [Solved]
- c.json
- (188.98 KiB) Downloaded 1864 times
- chaise.cubik
- (87.03 KiB) Downloaded 2013 times
- damaged_anvil.json
- (250 Bytes) Downloaded 1929 times
Re: The shape of the model does not appear [Solved]
I've solved the problem...
So if anyone has the same problem as me:
Actually one element was affecting the bounding box, which was not working for some reason. So I removed the texture pasting borders.
