Cubik pro  [Solved]
Cubik pro
Post by Acemanny » 28 Jun 2021, 01:40
i cant login to the cubik pro launcher I have tried everything i could think of and i don't know what else to do
Acemanny
Re: Cubik pro
Post by HanFox » 28 Jun 2021, 08:03
What exactly have you tried? What error do you get?
Re: Cubik pro
Post by Acemanny » 28 Jun 2021, 20:38
the error is saying the registration details are wrong but as far as I know it's correct its the same thing that i use to log into cubik studio so shouldn't it work? and maybe I am missing something but I have no idea what it would be. i have tried resetting the serial key which didn't work i even tried creating a new account but i can not seem to log into the BDcraft Cubik Pro
(edit) so i made a stupid and realized i was not using the updater by even still i cant use the serial key that i have it says it is invaild
Acemanny
Re: Cubik pro
Post by HanFox » 28 Jun 2021, 20:46
Cubik Pro has some issues on some systems.
We're not entirely sure of exact fixes, but generally it seems that at some level on your network the application gets blocked. Be it the firewall, a proxy, or router.
Some people have had success using a VPN, but we have no other advice to give (and Cubik Pro is no longer a supported product).
Re: Cubik pro  [Solved]
Post by Acemanny » 28 Jun 2021, 20:49
and i figured it out i am sometimes so dumb LOL
you need the updater.exe and you need to add the BCS- that is at the beginning of the serial key.
Acemanny
