I can't open cubik studio  [Solved]
Post by nichole » 20 Mar 2021, 19:59
Hello,
I have an issue with opening Cubik studio. The first time it was fine, it opened automatically after install. But how should I open it next time? I have no shortcut on my desktop, so I tried to open it with CubikStudio.exe - which is in a place where it should be installed. But it doesn't work. It says "Data folder not found. There should be 'CubikStudio_Data' folder next to the executable." Where I do a mistake? Or I am just an idiot and I should open it with the same file like the first time? XD It seems to be strange because downloading starts again.
Thanks for your answer and sorry for the possible mistakes, English is not my native language.
nichole
Re: I can't open cubik studio  [Solved]
Post by HanFox » 20 Mar 2021, 20:44
After running the updater the first time it should download the main program. It'll be automatically unpacked in the same folder, if it's not maybe try moving the Updater.exe to another location as it may not have permissions to unpack the program where you have it now.
Post by nichole » 20 Mar 2021, 20:51
HanFox wrote: 20 Mar 2021, 20:44 After running the updater the first time it should download the main program. It'll be automatically unpacked in the same folder, if it's not maybe try moving the Updater.exe to another location as it may not have permissions to unpack the program where you have it now.
Wow, now it works, thanks!
nichole
