Display Presets (Newes Version) [Solved]
Display presets, again not working, i know the location C:\Users\(NAME)\AppData\LocalLow\BDcraft\Cubik\presets, there are all my presents (.json), but cubik dont load they, is there a fix?
- CaptainGalax
- Likes: 13 x | 18 x
Re: Display Presents (Newes Version)
Have you created the not loading presets in 2.1?
If so, post a preset here which does not load and I'll tell you how to make it load again.
uhm, all presents (also the standart from 2.1) don´t loading,Sphax wrote: 19 Nov 2016, 11:16 Have you created the not loading presets in 2.1?
i made a video,
https://www.youtube.com/watch?v=YMfLHb7 ... e=youtu.be
And, here a example, from my Display present
"name": "Vanilla block",
"canBeRemoved": false,
"enable": true,
"rotation": [ 0, 0, 0 ],
"translation": [ 0, 3, 0],
"scale":[ 0.25, 0.25, 0.25 ]
SOrry for my bad english.
- CaptainGalax
Re: Display Presents (Newes Version) [Solved]
OK found the issue... I'm sorry, this should have been fixed in 2.2 but the fix did not fully worked.
Will be fixed in 2.3 (hopefully)
