Higher mesh to voxel conversion resolution
Post by Niron » 17 Feb 2020, 15:22
I purchased this tool exclusively for conversion of .obj to .json. The models look terrible with the current max conversion resolution. I would like to see an option to set it at least 10 times higher than is now currently possible. Thanks.
Niron
Re: Higher mesh to voxel conversion resolution
Post by Paul Saints » 18 Jun 2020, 23:40
I also want to because 128 resolution is too little. 256 resolution is good. What is the solution to increase?
128 limited resolution.png (8.07 KiB) Viewed 26169 times
Paul Saints
