Post
by Sphax » 17 Nov 2016, 18:56
3 x
- Admin
70 x | 223 x
Post
by KillzXGaming » 17 Nov 2016, 21:09
Wow that is one insane change long. I haven't used this program in a year and i can't believe how different this is. I'm curious, I noticd you can import obj files and meshes. Is there or will there be a way to map textures for those?
KillzXGaming
Post
by Sphax » 17 Nov 2016, 21:30
KillzXGaming wrote: 17 Nov 2016, 21:09
[...] Is there or will there be a way to map textures for those?
Cubik Studio can import meshes with textures. You can then, move, rotate and resize them before voxelize them.
- Admin
70 x | 223 x
Post
by AndrealVox » 17 Nov 2016, 22:04
Sphax wrote: 17 Nov 2016, 18:56
Left shift works in Elements list
Is it only left shift and not left ctrl as well? We still have to use right ctrl for single selections right?
AndrealVox
Post
by Petersoj » 17 Nov 2016, 22:53
Thank you so much for the work!
So clad that left shift now works for elements lists to select multiple elements!
Also, I don't think the Minify/Compact JSON feature is working on mac. There is no difference between exporting with or without it.
Also, a cool feature would be to minimize the character length for each texture since the word themselves are used many times throughout the JSON file.
Petersoj
Post
by CaptainGalax » 18 Nov 2016, 09:29
Display presents, again not working, i know the location C:\Users\(NAME)\AppData\LocalLow\BDcraft\Cubik\presets, there are all my presents (.json), but cubik dont load they.
CaptainGalax
13 x | 18 x
Post
by Sphax » 18 Nov 2016, 17:39
AndrealVox wrote: 17 Nov 2016, 22:04
Still Right Ctrl only for single selection for the moment.
CaptainG4laxy wrote: 18 Nov 2016, 09:29
Please create a topic if you have an issue. Btw, 2.2 will not import presets created in 2.1, that may be your issue.
- Admin
70 x | 223 x
