after i updata windows7 to 10 it cant be open.  [Solved]
Post by wolf_awwent » 30 Jan 2020, 08:54
when i open CubikUpdater.exe it looks like that
always black screen.
or someone can teach me how to make my windows back to 7?
I already updata it over 10 days. it said that i can return to windows7
圖片 1.png (5.18 KiB) Viewed 4029 times
wolf_awwent
Re: after i updata windows7 to 10 it cant be open.
Post by HanFox » 30 Jan 2020, 11:09
Firstly make sure your graphics drivers are up-to-date.
Next, try deleting the files located at:
%appdata%\..\LocalLow\BDcraft\Cubik
Post by wolf_awwent » 30 Jan 2020, 11:35
it already up to data
and i dont have " LocalLow "
wolf_awwent
Post by wolf_awwent » 30 Jan 2020, 11:38
i use nvidia 441.87
GeForce GTX 1050Ti
wolf_awwent
Re: after i updata windows7 to 10 it cant be open.  [Solved]
Post by HanFox » 30 Jan 2020, 13:34
When you update Windows via their update tools it generally keeps all your settings. It's odd you don't have that folder.
The only other advice I have, if you're definitely sure your graphics are up-to-date, is to delete the folder where the Cubik exes are and redownload them.
Cubik works fine on Windows 10, so the issue is with your computer, and I can't really give you much more information.
Post by wolf_awwent » 30 Jan 2020, 13:48
i already try delete all the cubik file and redownload,but it still keep black screen
I will try to make it back to windows 7, thanks.
wolf_awwent
