Textures dont load ingame?  [Solved]
Post by Codex » 16 Nov 2016, 15:31
Hey,
I dont know why but if I export an json and then open it Ingame the GUI texture shows but if I place down the Block, it wont
Block used: red_nether_brick
Mc version: 1.10.2
And btw, if I use Voxels, I need the Voxelpalet in my Texturepack, right? And if yes, where can I find it? :D
Ty for the help ^^
Codex
Re: Textures dont load ingame?
Post by Sphax » 16 Nov 2016, 15:37
If you use voxels, you need to convert them to elements before exporting to Minecraft JSON.
After conversion you need to export to JSON and save the generated texture.
To save the generated texture, you have 2 ways:
  1. Save it manually: right click on texture > Save texture
  2. Always export texture aside Minecraft JSON: Go in Tools > Preferences > Formats > Save textures as png on export (aside json)
Post by Codex » 16 Nov 2016, 15:41
Omg thank you <3 Your answered so fast :§
Codex
Post by Codex » 16 Nov 2016, 16:18
Another short question, this ist the http://hastebin.com/juyihenivo.json json file and the Problem is the Textures dont show up ingame, they are located in the textures/blocks
Any idea ?
Codex
Post by Sphax » 16 Nov 2016, 16:35
if "textures/blocks/SurgeyTable1.png" file and "blocks/wool_colored_cyan" exist in your RP your model should be textured.
Post by Codex » 16 Nov 2016, 16:59
They do but it still doesnt load... ;(
Codex
Post by HanFox » 16 Nov 2016, 17:55
For MC1.10 all files/folders in RPs have to be lowercase. i.e. you need to change SurgeyTable1.png to be called surgeytable1.png
Post by Codex » 16 Nov 2016, 18:15
Im sorry to annoy you, but im still stuck. So if it helps you in anyway, I can give you the resource Pack with the json (purpure_block i guess) And the textures etc, I used Mc 1.10.2
File: http://www.mediafire.com/file/0j1edbfxe ... ckPack.zip
Codex
Post by HanFox » 16 Nov 2016, 18:40
I made a mistake when I said about filenames that was a change only implemented in MC1.11, but future proofing, hey? :P
Regardless, your model errors because it falls outside of the allowed range for MC (-16 to +32).
18:39:43] [Client thread/WARN]: Unable to load block model: 'minecraft:block/purpur_block' for variant: 'minecraft:purpur_block#normal': com.google.gson.JsonParseException: 'to' specifier exceeds the allowed boundaries: Vector3f[37.5, 13.0, 15.0]
[18:39:43] [Client thread/WARN]: Unable to load block model: 'minecraft:block/purpur_block' for variant: 'minecraft:purpur_double_slab#variant=default': com.google.gson.JsonParseException: 'to' specifier exceeds the allowed boundaries: Vector3f[37.5, 13.0, 15.0]
[18:39:43] [Client thread/WARN]: In parent chain: minecraft:item/purpur_block -> minecraft:block/purpur_block; unable to load model: 'minecraft:block/purpur_block'
That refers to:
			"__comment": "Cube5",
			"from": [ 18.5, 12, 1 ],
			"to": [ 37.5, 13, 15 ],
			"rotation": { "origin": [ 18.5, 12, 1 ], "axis": "z", "angle": 45 },
			"faces": {
				"down": { "uv": [ 0, 0, 16, 16 ], "texture": "#texture", "cullface": "east" },
				"up": { "uv": [ 0, 0, 16, 16 ], "texture": "#texture", "cullface": "east" },
				"north": { "uv": [ 0, 0, 16, 16 ], "texture": "#texture", "cullface": "east" },
				"south": { "uv": [ 0, 0, 16, 16 ], "texture": "#texture", "cullface": "east" },
				"east": { "uv": [ 0, 0, 16, 16 ], "texture": "#texture", "cullface": "east" }
Post by Codex » 16 Nov 2016, 18:46
Ohhhhhhhh, Thank you so much, im dumb xD So I cant use all 3x3x3 Blocks ? So what exactly am I allowed to do ? :D
And yes future proofing :D Good to know so I dont suffer on that in the futer ^^
But also Thank You for the answer!!
Codex
