Unable to import JSON files! (Ctrl+i)
Post by MadstonMagic » 13 Jul 2019, 17:24
Good day Sphax & HanFox (+ other devs),
Since a few months back actually, Cubik on both my laptop and PC is having issues importing json files.
I have models that are properly written json, but for some reason when I try to import them into Cubik Studio... nothing happens.
After this occurs, no error is given nor any indication of what is wrong.
I cannot find any error log either.
Please fix this, because for some reason it just stopped working.
I also tried deleting all data and re-download a clean version.
- MadstonMagic
MadstonMagic
Re: Unable to import JSON files! (Ctrl+i)
Post by HanFox » 13 Jul 2019, 19:48
Try deleting the files located at:
%appdata%\..\LocalLow\BDcraft\Cubik
Post by MadstonMagic » 14 Jul 2019, 19:52
HanFox wrote: 13 Jul 2019, 19:48 Try deleting the files located at:
Aight, thanks Han!
MadstonMagic
Post by MadstonMagic » 21 Jul 2019, 13:42
Hello again, I have found out WHEN the program starts refusing importing JSON models.
When I tried to change the settings from inside the program (Not through navigating to the json file and manually edit it), it started occurring again.
Te be 100% precise, I enabled 'FIle Browser -> 'use Native file browser if possible' ' when it happend again.
The whole saving of the settings json is a little wanky.
It does not always save what has been changed inside the program.
For example the paths. (Which still are not "last opened" as it is in Cubik Pro (Which worked WAY better that way))
Please take this in consideration for an update!
MadstonMagic
