Ill use a picture to better explain my predicament.
http://imgur.com/a/5VDjh
Textures aren't rendering correctly in MC [Solved]
- Beardlessbrady
Re: Textures aren't rendering correctly in MC
Without being able to see the actual JSON I suspect for the faces that are disappearing you have culling on those elements set to Down.
That seems to be the problem thanks! question though, I don't fully understand what culling does, can you briefly explain what it does?
- Beardlessbrady
Re: Textures aren't rendering correctly in MC [Solved]
Source: http://minecraft.gamepedia.com/Modelcullface: Specifies whether a face does not need to be rendered when there is a block touching it in the specified position. The position can be: down, up, north, south, west, or east. It will also determine which side of the block to use the light level from for lighting the face, and if unset, defaults to the side.
- Beardlessbrady
