Dear HanFox (or other administrators...) ,
Me the other day when working with the factory's laptop have landed cubik, don't do it now, come home, because home computer is bad, I have to go to the Internet cafe to use the software, I always want to go to Internet cafes are not way, looking back I keep their computers replace system want to make do with, but I found that has not been on board, the discord ask know after multiple computers using key will record the IP can only be reset key, so I beg you to help me to reset the key.
Thank you for your
GuoMengHao
Request a reset key [Solved]
Re: Request a reset key
Your key doesn't currently require resetting as it still has uses left.
Why is that?
The same thing happens when you start the software. The key is all right, but OK can't be clicked
Reason: Removed image
Re: Request a reset key [Solved]
Make sure you're entering the information correctly from https://cubik.studio/get
Make sure your computer's clock is set correctly.
If you're behind a proxy make sure it is set up correctly.
Thanks, we have solved it. The original clock should be set correctly
