I wan't to have 2 computer with Cubik Studio but if I wan't to login I says that the key is already activated on to many account, how can you logout for that pc?
Is it possible to get a reset?
Logout [Solved]
Re: Logout [Solved]
I checked and you hadn't actually used up all your uses. There's an error in the checking script.
For now I have reset your uses and hopefully Sphax will fix the checking script soon.
