I accidentally used the previous activation code, resulting in the account being blocked and requesting an unblocking  [Solved]
Post by jiri » 24 Jun 2018, 03:05
My CubikStudio was blocked by accidentally using the previous activation code when logging in, requesting unblocking
jiri
Re: I accidentally used the previous activation code, resulting in the account being blocked and requesting an unblockin  [Solved]
Post by HanFox » 24 Jun 2018, 09:57
Using your old key would have no effect.
You've used up your activations with your new key.
As I previously told you your activations won't be reset again.
