Post
by jiri » 05 Jun 2018, 14:00
jiri
Post
by HanFox » 05 Jun 2018, 19:00
We don't lock accounts to IPs.
It would follow after your last request that you're sharing your key, changing your password wouldn't fix the issue as your password is only used to access this website (obviously if you shared your password you should still change it).
If you believe someone else is still using your key we can change it for you, but this is a very good example of why you shouldn't share your credentials with other people.
If you would like your key changed in order to re-secure your product we can do so, however, if you use your activations up again any time soon we won't reset your account again.
- Web Admin
30 x | 76 x
Post
by jiri » 05 Jun 2018, 19:09
Can you tell me specifically what I should do to ensure that I can continue to use cubik studio normally?
jiri
Post
by HanFox » 05 Jun 2018, 19:11
If you ever gave your password out, you should change it.
If you ever gave your Cubik Studio BCS key out - whilst that breaches the
Terms of Use you agreed to and we're not obliged to do anything - I'm willing to change your key so people will no longer be able to access your product.
- Web Admin
30 x | 76 x
Post
by jiri » 05 Jun 2018, 19:16
How can the changed key be sent to you?
jiri
Post
by HanFox » 05 Jun 2018, 20:59
jiri wrote: 05 Jun 2018, 19:16
You'll be able to see your new key via
https://cubik.studio/get
You just need to confirm to me that is what you want to do, and that you're not going to share your key again.
- Web Admin
30 x | 76 x
Post
by jiri » 06 Jun 2018, 04:38
ok,I've changed it.
jiri
Post
by jiri » 06 Jun 2018, 04:40
My key has been modified,.......sorry, I'm not good at English.
jiri
Post
by jiri » 06 Jun 2018, 09:57
HanFox wrote: 05 Jun 2018, 20:59
My key has been modified. Can I continue to use cubik studio next? Is it a specific way to replace the serial key or?
jiri
Post
by HanFox » 06 Jun 2018, 11:01
I'll take your replies as confirmation you want me to change your key and that you're not going to share it again then.
You can see your new key on
https://cubik.stuido/get
If you share your key again it won't be reset.
- Web Admin
30 x | 76 x
