Is Cubik 1.13 Compatible?  [Solved]
Post by Lord_Z_ » 27 Apr 2018, 02:36
I want to use one of my 3d models for the 1.13 snapshots but no matter what I do it always just turns into a black and purple cube.
Can anyone help?
- Lord_Z_
Lord_Z_
Re: Is Cubik 1.13 Compatible?  [Solved]
Post by HanFox » 27 Apr 2018, 08:07
Yes, it does support MC1.13 as nothing changed in the modelling system.
If you're having issues with a model you should check your Minecraft log files to see if it tells you the error.
