Slightly moving elements via UP,DOWN,LEFT,RIGHT
Post by CombatBorn » 11 Mar 2018, 06:13
When you select an element in Cubik Studio, you're able to move the selected element(s) around by a SET, small, distance through using the UP,DOWN,LEFT,RIGHT keys. Is there any way (using the current Cubik version) to move these element(s) at a lesser distance for more precise arrangements?
SIDE NOTE: I know I can right-click the selected element(s) in the element list, click "move", then enter the X/Y/Z, but I would want to use the UP,DOWN,LEFT,RIGHT arrows so I can save hours of my time.
Thanks in advanced.
CombatBorn
Re: Slightly moving elements via UP,DOWN,LEFT,RIGHT
Post by Sphax » 11 Mar 2018, 10:06
You can set the grid snap for keyboard in View > Grid
Post by CombatBorn » 12 Mar 2018, 18:46
Thanks, so far so good. I noticed however that using the method only goes to 512, and sometimes the elements aren't entirely connected. Hard to tell further away, but it's a noticeable up close.
This is Halo shotgun I'm working on for a client right now:
(Almost done)
CombatBorn
