test [Solved]
Re: Texture saving seperately from json file
disregard
Re: Texture saving seperately from json file [Solved]
If Cubik tells you that the textures you are using on model must be saved, then save them in your ResourcePack and verify that your json is actually pointing to right path for textures.
