scaling+rotation not carrying over ingame
Post by James720 » 28 Jul 2017, 03:23
When i scale and/or rotate the item in cubik, save it, and load up mc, the item is not rotated and/or scaled in game. Is there a fix for this? Something im doing wrong?
James720
Re: scaling+rotation not carrying over ingame
Post by Sphax » 29 Jul 2017, 15:46
Have you checked "Export settIngs"?
Post by MooshroomStatus » 29 Jul 2017, 22:30
I'm having the same issue with the new update. I looked into it and item scaling isn't being wrote into the .JSON files, only translation and rotation. I was able to fix it by manually adding the "Scale" line into the file and using the sizes I used in my previews.
MooshroomStatus
Post by Sphax » 30 Jul 2017, 14:32
Do you have a 3D model to share with that Issue?
