Can't Move Imported Object [Solved]
Re: Can't Move Imported Object
@Jimmy and @Stadalf :
- Are you on MacOSX version?
- Do you always reproduce the issue in a step by step guid right after launching Cubik?
- Do you always reproduce the issue after a Cubik restart?
Same here, using Windows. As I see that when you try to import something really big you can't convert it to voxels or move also delete.
Re: Can't Move Imported Object [Solved]
The bug should be fixed for next update. It only happens when no texture are set on the imported OBJ. Works well on OBJ with textures.
I got the same problem, import .obj into studio and i can't do anything with it
