New function "Reset color" in Voxel tools
Improved Paint tools line and brush tools when used on voxels
Improved Paint tools when used on texture with right mouse button (draw transparent on textures)
.cubik format now saves Display Settings
.cubik format now saves origin and model box
Display settings modifications are undo/redo-able
Implemented Undo/Redo for Voxelization function
Added new function to Mesh edit-mode "Clear meshes textures"
Added confirmation message box on Mesh edit-mode functions when no selection or no mesh
Added a new "Convert voxels to elements" function which generates an atlas for a lot less elements but bigger texture
Implemented better name for texture generated after conversion from voxels to elements
Cubik Studio now displays a message box when an update is available and allows to launch Cubik Updater easily
Cubik Studio now displays a message box on first launch after being updated with possibility to read changelog online
- Removed black square in UI on bottom left corner
- Fixed broken functions on buttons "Show", "Hide", "Lock" and "Unlock"
- Added an error if "Share on Sketchfab" option is selected but API token is missing
- Improved overall stability, specifically on MacOSX
- Fixed bug preventing dynamic dropdowns to be displayed (like presets and textures)
- Fixed bug on redo conversion to elements which was displaying wrong texture on elements
- Fixed bug with "Share on Sketchfab" function not working if mesh exporters are disabled
- Fixed bug which produced black elements after voxel conversion
- Fixed bug on undo conversion to voxels which was keeping generated texture
- Fixed bug with not undo-able Material Manager functions "Create atlas"
- Fixed bug with non working function "Views" > "Delete all backgrounds"
- Fixed several bugs when actions modifying element(s) textures were undone
- Fixed bug with pasted UVs which was not disabling "Snap UV" option
