Texture error help me  [Solved]
Post by whitepaper » 07 Jul 2024, 11:49
If you import it after modeling and apply the resource pack, this is how the error occurs. How do I solve it
whitepaper
Re: Texture error help me  [Solved]
Post by HanFox » 08 Jul 2024, 07:15
When you're making models all the files are best placed in a the location they'd be in a real resourcepack, that way Cubik will know the correct path when importing textures, etc.
You can fix it 2 ways:
Re-import the texture in the correct location from the resourcepack and then re-export the model;
Or edit the exported json file's texture path to be correct (usually something like minecraft:textures\item\iron_sword )
