The shape of the model does not appear  [Solved]
Post by Mathdn » 30 Jun 2022, 19:10
Hello,
I have a problem with the template form not displaying, and I can't find the source of the problem. There is a black and purple block instead.
I am attaching the .cubik file, the blockstate file and the .json template.
For information, the replaced block is the damaged anvil.
If you need more information, please let me know.
Thank you for your help :)
c.json
(188.98 KiB) Downloaded 1925 times
chaise.cubik
(87.03 KiB) Downloaded 2077 times
damaged_anvil.json
(250 Bytes) Downloaded 1986 times
Mathdn
Re: The shape of the model does not appear  [Solved]
Post by Mathdn » 30 Jun 2022, 20:50
I've solved the problem...
So if anyone has the same problem as me:
Actually one element was affecting the bounding box, which was not working for some reason. So I removed the texture pasting borders.
Mathdn
