Not able to use app  [Solved]
Not able to use app
Post by FrontierTD » 31 Mar 2022, 22:39
When I try to login I get a message that says the licenses can't be validated
FrontierTD
Re: Not able to use app
Post by HanFox » 01 Apr 2022, 10:38
Firstly make sure your system clock is set correctly, then make sure you're entering your details exactly as they appear on https://cubik.studio/get
Post by FrontierTD » 01 Apr 2022, 16:05
The clock is correct and I copy and pasted from the website
FrontierTD
Re: Not able to use app  [Solved]
Post by HanFox » 01 Apr 2022, 16:48
I've tested your details and they work correctly.
Try deleting the following folder and trying to validate your details again:
C:\Users\<user>\AppData\LocalLow\BDcraft\Cubik
Post by FrontierTD » 02 Apr 2022, 00:46
I got it working on my other computer. Thank you for the help.
FrontierTD
