Not able to use app [Solved]
Not able to use app
When I try to login I get a message that says the licenses can't be validated
- FrontierTD
Re: Not able to use app
Firstly make sure your system clock is set correctly, then make sure you're entering your details exactly as they appear on https://cubik.studio/get
The clock is correct and I copy and pasted from the website
- FrontierTD
Re: Not able to use app [Solved]
I've tested your details and they work correctly.
Try deleting the following folder and trying to validate your details again:
C:\Users\<user>\AppData\LocalLow\BDcraft\Cubik
I got it working on my other computer. Thank you for the help.
- FrontierTD
