Hello,
I noticed that I can no longer open nor import any old .bdc3d files that were affiliated with the old Cubik PRO.
Is there a solution to this problem? I've lost quite a bit of models just because of this.
Thanks!
- Profyle (aka Breaks)
Cannot open/import old .bdc3d files [Solved]
Re: Cannot open/import old .bdc3d files
The solution is to import them in Cubik Pro and export them as JSON files.
Sphax, at a later date, may make a converter or add support for bdc3d.
Okay, thanks.HanFox wrote: 02 Nov 2016, 02:15 The solution is to import them in Cubik Pro and export them as JSON files.
Now all I need to do is hope that Cubik PRO is still just in the Recycling Bin
