Requesting Refund  [Solved]
Requesting Refund
Post by ShadowFox1308 » 31 Dec 2020, 04:33
This product does not open, nor gives me a reason why or a way to solve this. The product has not been made available to me and I have no way to open it or run it in any way. It is for this reason that I am requesting a refund, I can't use this product and its not been made available to me even though I have tried downloading It multiple times the application will not open. I would like a refund.
ShadowFox1308
Re: Requesting Refund
Post by HanFox » 31 Dec 2020, 10:06
If you've managed to download the software to your system, then it has been made available to you.
However, if you are having issues, maybe we can help you with them.
What operating system do you use?
What exactly happens when you try to run the software?
Post by ShadowFox1308 » 31 Dec 2020, 12:18
I use a Mac, ive seen some stuff about doing a certain command but I wouldn't know how to do that. And when I try to run the software it just says that it can't be opened with no explanation as to why.
ShadowFox1308
Post by HanFox » 31 Dec 2020, 14:25
Newer version of Mac seem to have changed a bit, causing some minor issues.
To get it to run now you can try the following:
Note: that when you see {space} below it means press the spacebar.
  1. Open terminal.
  2. Type
    sudo chmod -R 755 {space}
  3. Then drag and drop the Cubik Updater from the directory in which you wish for the application to be installed.
  4. Press enter
  5. Enter your password at the prompt
  6. Right click and press open in the directory which the file is in, by default it will tell you that the application is unknown.
  7. Run the file, put in your information and you're done!
Post by ShadowFox1308 » 03 Jan 2021, 21:29
Just tried doing that and it still hasn't worked? still got the same message as before
ShadowFox1308
Post by HanFox » 05 Jan 2021, 12:06
I see. I'm not sure what else to suggest. Not everyone has issues...
If you still want a refund I can get that sorted for you?
Post by ShadowFox1308 » 04 Feb 2021, 00:23
Hiya, Still have not been able to open this application could I please get a refund? I even tried letting someone a lot more professional then I am take a look but it still didn't open.
ShadowFox1308
Re: Requesting Refund  [Solved]
Post by HanFox » 04 Feb 2021, 12:25
I have processed a refund for you.
You should receive a confirmation, and the monies returned to you shortly.
Sorry you had issues with the product.
Post by kingking » 13 Feb 2021, 22:45
I didn't know if it was bought by mistake, and I bought Cubik Studio twice.
The other one is being used, the other one is not at all. Can I return this?
실수로 구매가 된 지 모르고, 큐빅 스튜디오를 2번이나 구매했습니다.
나머지 한개는 쓰고있으나, 다른 나머지 한개는 전혀 쓰고있지 않습니다. 환불이 가능한가요?
kingking
