OBJ -> Voxels Conversion Bug  [Solved]
Post by Profyle » 06 Nov 2016, 21:25
... as well as another "bug" that was found unexpectedly.
Profyle
Re: OBJ -> Voxels Conversion Bug  [Solved]
Post by Sphax » 06 Nov 2016, 22:33
To work around first bug, check "Keep inside empty"
Post by Profyle » 06 Nov 2016, 22:34
Sphax wrote: 06 Nov 2016, 22:33 To work around first bug, check "Keep inside empty"
Thanks for this, but I already knew. I was just reporting it ;)
Profyle
Post by Sphax » 06 Nov 2016, 23:03
2nd bug should be fixed in next update ;)
For the 1st bug, it's due to tiny details making the fill process miss the shell side when exiting... not sure yet how to fix that
