0 elements when importing model? [Solved]
Post by ReduxRedstone » 02 Nov 2016, 01:46
When importing a voxel model made in MagicaVoxel (this could be happening for models made in other programs as well, but I only have MagicaVoxel) the model says it has 0 elements, yet displays the model correctly.
Imgur GIF of what I mean
ReduxRedstone
Re: 0 elements when importing model?
Post by Sphax » 02 Nov 2016, 09:10
You've imported a voxel model. If you want to convert voxels to elements, just go in "Voxel" edit mode, then click "..." and select "Convert to elements". ;)
Post by ReduxRedstone » 02 Nov 2016, 13:41
Sphax wrote: 02 Nov 2016, 09:10 You've imported a voxel model. If you want to convert voxels to elements, just go in "Voxel" edit mode, then click "..." and select "Convert to elements". ;)
Thanks :D
ReduxRedstone
