Higher mesh to voxel conversion resolution
I purchased this tool exclusively for conversion of .obj to .json. The models look terrible with the current max conversion resolution. I would like to see an option to set it at least 10 times higher than is now currently possible. Thanks.
1 x
Re: Higher mesh to voxel conversion resolution
I also want to because 128 resolution is too little. 256 resolution is good. What is the solution to increase?
- Attachments
- 128 limited resolution.png (8.07 KiB) Viewed 26170 times
- Paul Saints
- Likes: 1 x
