I went to install cubik and upon launching the installer, it is wider than both my monitors, Ubuntu crashes a few seconds later.
I am on Ubuntu 20.04, as this is a new release, I guess incompatibilities are to be expected.
Installer Unusable on Ubuntu 20.04
- Ninja_Hinja42
Re: Installer Unusable on Ubuntu 20.04
If you try running the update in the Terminal what output do you get?
Hi, I too am having issues getting Cubik Studio to load on Ubuntu 20.04
here is my terminal.
"client has 4 screens" I am on a laptop with no external monitors so idk what this is talking about. also when I try to run the updater (i guess is the installer) most of the times it results in some sort of crash (forcing me to logout).
bamajoe411@jb-ubuntu-zbook:~/Downloads/cubik_updater_linux$ ./cubikupdater.x86_64
Set current directory to /home/bamajoe411/Downloads/cubik_updater_linux
Found path: /home/bamajoe411/Downloads/cubik_updater_linux/cubikupdater.x86_64
Mono path[0] = '/home/bamajoe411/Downloads/cubik_updater_linux/cubikupdater_Data/Managed'
Mono path[1] = '/home/bamajoe411/Downloads/cubik_updater_linux/cubikupdater_Data/Mono'
Mono config path = '/home/bamajoe411/Downloads/cubik_updater_linux/cubikupdater_Data/Mono/etc'
displaymanager : xrandr version warning. 1.6
displaymanager screen (0)(DP-3): 1920 x 1080
Using libudev for joystick management
Importing game controller configs
Aborted (core dumped)
- bamajoe411
