Cubik serial key reset [Solved]
I want to reset the key because I reinstalled the windows and then I entered the program, so I want to reset.
- patter3505
- Likes: 1 x
Re: Cubik serial key reset [Solved]
The reset form reminds you every time you manually reset your uses that if you keep resetting your key it may become unusable.
Your key won't be eligible for another reset until roughly April, 2020.
