Texture is showing up as a big ´Missing Texture´.
Post by KingALLO » 18 Nov 2018, 17:51
I really need help please guys !!
I was making a ladder texture for my texture pack (its only private use) and I put the default minecraft oak wood texture on it so it looks ok .
Problem is ... ingame the texture is a t least twice as big and on the wrong side + it has No Texture (pink and black chess coloured) .
I would be emensly happy if you´d help me out guys and women ... Im pretty sad I couldnt do it ...
KingALLO
Re: Texture is showing up as a big ´Missing Texture´.
Post by Sphax » 31 Jan 2019, 11:49
Post the exported json so we can help
Post by KingALLO » 07 Apr 2019, 22:15
Sphax wrote: 31 Jan 2019, 11:49 Post the exported json so we can help
Its added as a file ... i really dont know what it could be checked everything i could find that could´ve been the error
ladder.json
(4.72 KiB) Downloaded 255 times
KingALLO
Post by KingALLO » 07 Apr 2019, 22:16
Btw its not as big anymore but still missing the texture
KingALLO
Post by HanFox » 07 Apr 2019, 22:25
"texture": "C:\Users\media\AppData\Roaming\.minecraft\resourcepacks\Cubik Default 1.12\assets\minecraft\textures\blocks/planks_oak"
Not sure how you managed that. The path of your texture should be relative to the textures folder, so should should just be:
"texture": "blocks/planks_oak"
or for MC1.13 and above:
"texture": "block/oak_planks"
