texture wont load
texture wont load
Post by Jenthe » 21 Feb 2019, 20:44
Dear cubik model makers
I have made / converted a model for a gamemode a friend is making.
I can load the model ingame. It is set to diamond_ore.JSON
the texture is currently loaded as texture and it is placed in the texture/block folder.
Could anyone help me find why i can't get the texture to load.
Kindest regards
Jenthe
files in attachment
diamond_ore.json
(1.63 MiB) Downloaded 242 times
Jenthe
Re: texture wont load
Post by HanFox » 22 Feb 2019, 01:55
The top of your file for texture paths looks incorrect:
	"textures": {
		"model_atlas": "texture",
		"particle": "texture"
The "texture" part should be the relative path to the actual texture, using assets/minecraft/textures as the root (i.e. if the texture is assets/minecraft/textures/block/diamond_ore texture should be changed to block/diamond_ore).
The best way to make models is to actually do it within a valid structure, that way Cubik will read the paths correctly when you add files from the beginning.
