Error with model and texture in Minecraft
I was editing a .png minecraft sword based on the tutorial by sphax, but in the world the model and texture are just broken. Images.
Re: Error with model and texture in Minecraft
Towards the top of your json I suspect your "texture" and "diamond_sword" are wrong. The path should reflect the location in the resourcepack. It's more likely your texture is inside the item folder.
So:
Although items generally don't need "particle" and if you're referring to "diamond_sword" everywhere you don't need the "texture" either.
So:
"textures": {
"particle": "items/diamond_sword",
"texture": items/diamond_sword",
"diamond_sword": items/diamond_sword"
Ok I will try without it but these paths were created by Cubik Studio so...
OK i have tried it but it didn't changed anything. I uploaded the model and the texture for everybody who wants to check through http://www.mediafire.com/file/f61ekug7n ... exture.zip
Your texture should be in assets/minecraft/textures/items and in the json on line 4 and 5 the path should be items/diamond_sword.
All textures are always relative to assets/minecraft/textures. They can't be alongside the json.
The easiest way to make models is to work within the correct structure from the start. Textures should always be in the textures folder, then Cubik will always set the paths correctly automatically.
My textures are in the texture folder for items i just had a copy laying around in the models folder aw.
"__comment": "Designed by anikin",
"textures": {
"texture": "items/diamond_sword",
"diamond_sword": "items/diamond_sword"
"__comment": "Box920",
"from": [ 31.8871, 8, -15.6047 ],
"to": [ 32.00004, 9, -15.54823 ],
Red elements in the Cubik element list usually have some sort of error attached to them, and Minecraft's game log will tell you the actual error:
[18:40:18] [Client thread/WARN]: Unable to load model: 'minecraft:diamond_sword#inventory' referenced from: minecraft:diamond_sword#inventory: com.google.gson.JsonParseException: 'to' specifier exceeds the allowed boundaries: cph@64695f76
